Re: flaky gas tank
Posted by gene b on October 01, 2002 at 16:57:09 from (63.15.134.86):
In Reply to: flaky gas tank posted by Terry on October 01, 2002 at 15:59:16:
i put one of those FRAM see thru filters in line between the sediment bowl and the carb using rubber hose that way can see the dirt and is easy to clean and change
Post A Followup
: Re: Re: flaky gas tank
