Re: Farmall 350 Tach
Posted by Harry on October 02, 2002 at 12:29:02 from (4.63.64.91):
In Reply to: Farmall 350 Tach posted by Jim Z on October 01, 2002 at 09:56:23:
Find an old ignition testor that has an electronic tach built into it. (I have an old dwell & tach unit from the 70's) Hook it up to the coil and compare the tach readings to your mechanical tach. It will tell you if your mechanical tach is working correctly.
Check out e-bay for a cheap one. Here is one that comes with a timing light from Sears..
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1864489386
Post A Followup
: Re: Re: Farmall 350 Tach
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
