Farmall Tractors Discussion Board
Re: Polarized ?
Posted by The Red on August 23, 1999 at 08:26:20 from (206.246.187.2):
In Reply to: Polarized ? posted by p on August 23, 1999 at 08:06:24:
p just take a 14 gauge wire or so and briefly touch the battery and generator posts on the voltage regulator to make a spark. If it doesn't charge after doing that then you probably have generator problems.
Post a Followup
: Re: Re: Polarized ?
