Re: manifold help on H
Posted by Larry F on October 02, 2002 at 21:36:30 from (216.202.132.34):
In Reply to: manifold help on H posted by Kelly C on October 02, 2002 at 20:44:17:
Kelly - This could either be very easy or a nightmare. When I removed my manifold everything came off fine..your mileage may vary. I would be patient and soak the manifold bolts with PB Blaster/Liquid Wrench or similar stuff. Let it soak for a day or so and spray it every couple hours. If you break a stud be very careful using an 'Easyout' they can cause more problems than they solve if they break off. Drilling an 'Easyout' is darn near impossible. I would suggest using a reverse twist drill bit if you snap a stud and forget the 'Easyout'. Take your time and let the penetrant work and you probably won't have any problems. Good luck. BTW nice website.
Post A Followup
: Re: Re: manifold help on H
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
