Re: Re: Re: '50 H Electric Help!
Posted by Ira on October 03, 2002 at 06:06:44 from (205.188.209.78):
In Reply to: Re: Re: '50 H Electric Help! posted by Krey in Indiana on October 02, 2002 at 11:25:55:
Check your wording on your literature that came
with the alternator it should say look for a
13.5-14.5 voltmeter reading during proper
operation. An ammeter reading will start high
right after you draw current from your battery
then as you run the tractor you are putting a
charge back in the battery which will raise the
voltage but will drop the current flow. An
Ammeter reads current flow. Voltmeter reads how
many volts is in the battery.
Post A Followup
: Re: Re: Re: Re: '50 H Electric Help!
