Re: Broken oil indicator valve
Posted by JONATHAN MIRGON on October 03, 2002 at 07:43:25 from (206.183.252.115):
In Reply to: Broken oil indicator valve posted by GooseCreek Farms on October 03, 2002 at 05:56:47:
I HAVE AN (A) AND I REPLACED BOTH OF THEM ON MINE. IM PRETTY SURE THEY USE THE SAME OIL PAN. THEY ARE THREADED IN FROM THE OUTSIDE, SO YOU SHOULD NOT HAVE TO TAKE OFF THE PAN, SOAK IT DOWN WITH PENETRATING OIL FIRST. IT TOOK A 12" PIPE WRENCH TO GET MINE OUT.
GOOD LUCK
Post A Followup
: Re: Re: Broken oil indicator valve
