Re: FARMALL (A) WATERPUMP ???
Posted by Red Dave on October 03, 2002 at 08:16:42 from (24.104.94.34):
In Reply to: FARMALL (A) WATERPUMP ??? posted by JONATHAN MIRGON on October 03, 2002 at 07:48:06:
It was an add-on. Usually added if there were overheating problems.
All A's used the thermosyphon system from factory. Some later model C's and Super A's had a waterpump from the factory. I think you can order one and bolt it on, it should include a different upper water outlet, the original doesn't have a place for a thermostat.
If the water passages in the block and radiator are clean, not blocked with sediment, you probably don't need a waterpump.
See my answer to your question below.
Post A Followup
: Re: Re: FARMALL (A) WATERPUMP ???
