Farmall Tractors Discussion Board
Re: A engine vs C engine
Posted by Stan(VA). on August 23, 1999 at 13:41:27 from (207.79.164.6):
In Reply to: A engine vs C engine posted by Rosco on August 23, 1999 at 08:48:27:
A/B 113 w/o hyd pump cutout in the block.
C/SA 113 with hyd pump cutout in the block. C governed at 1650 as stated earlier.
SC/SA-1 123 with hyd pump...
These are all sleeved engines: you can get standard rebuild kit with 3" or 3 1/8" pistons and sleeves respectively; or you get an overbore kit that includes thinner sleeves that allows the 3" block to receive 3 1/8" pistons, and the 3 1/8" block to receive 3 1/4" pistons. Some suppliers also have standard or higher compression options.
You don't bore these blocks unless you are trying to fit a larger sleeve in an earlier block. The simplest and cheapest upgrade is to use the overbore piston/sleeve kit.
Stan(VA).
Post a Followup
: Re: Re: A engine vs C engine
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
