Re: Farmall H clutch?
Posted by Steven@nd on October 06, 2002 at 20:17:56 from (12.23.184.123):
In Reply to: Farmall H clutch? posted by Bob on October 06, 2002 at 18:32:12:
No adjustment for that. Something is wrong with either your pressure plate surface, flywheel surface, or the surfaces on the clutch disk.
If it wasn't spotlessly clean when you put it together it can do that. I've had clutches chatter because of 1 drop of oil on them. I always clean with brake parts cleaner then use clean rags to handle the parts so I don't even get a finger print on them.
It could be something else, but I wouldn't know what it is.
Steven
Post A Followup
: Re: Re: Farmall H clutch?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
