Re: IHC Cub Hydraulic Unit
Posted by Bob on October 08, 2002 at 05:02:05 from (66.97.6.92):
In Reply to: IHC Cub Hydraulic Unit posted by Jim Criss on October 07, 2002 at 19:47:05:
The two lines are the feed and return from the pump mounted on the engine. The kit can be found at case IH dealer. Take the number off the block of the hydraulic unit. There was two different unit. Get yourself a set of manuals while you are there. The unit has no filter but a screen so make sure it stays clean while it is apart.
Post A Followup
: Re: Re: IHC Cub Hydraulic Unit
