Re: FARMALL A Hour meter
Posted by Steven@nd on October 08, 2002 at 06:27:17 from (12.15.56.3):
In Reply to: FARMALL A Hour meter posted by Chris on October 08, 2002 at 06:09:28:
This is how I put an electric hour meter on my H. I got a waterproof hourmeter that operates on 4 to 40 volts from JCWhitney. See pic below. Click here to buy the hourmeter.
third party image
Then I bought a Single Pole Double Throw toggle switch from Parts Express. See the diagram to understand how a SPDT switch works. Click here to buy an SPDT switch.
third party image
I mounted the hourmeter under the gas tank on my H, see pics.
third party image
third party image
Now when I flip the toggle switch up, it ungrounds the magneto and grounds the hour meter so it runs.
If you have a distributor you can just hook the negative side of the hour meter to your push pull switch on the same wire that goes to the coil(assuming you have a positive ground system).
Hope this helps!
Steven
Post A Followup
: Re: Re: FARMALL A Hour meter
