Re: Re: Ignition coil follow up Question
Posted by Lloyd on October 08, 2002 at 09:10:02 from (207.177.71.142):
In Reply to: Re: Ignition coil follow up Question posted by BIG JOHN on October 07, 2002 at 18:13:13:
If you use a resistor when you don't need one you will reduce the voltage at the primary of the coil. That will reduce the high voltage produced by the coil giving you weak spark. The engine may run, but not as well as it could with a proper spark.
Post A Followup
: Re: Re: Re: Ignition coil follow up Question
