Re: How much TNT to blow up a 1486?
Posted by scottAR on October 08, 2002 at 19:04:30 from (209.194.159.174):
In Reply to: How much TNT to blow up a 1486? posted by mgb on October 08, 2002 at 18:35:06:
Start at your battery posts with a voltmeter while cranking, then move the leads, one side at a time at every place you can until you get to the starter. I have had several Delco battery cables look perfectly good but they would loose connection inside the mold. If you don't have good voltage at the battery then the batteries are at fault. Make sure your ground cable is not hooked to one of those rubber bushing bolts.
Post A Followup
: Re: Re: How much TNT to blow up a 1486?
