Re: Looking for info on a farmall H sickle bar mower.
Posted by Hugh MacKay on October 09, 2002 at 01:57:31 from (216.208.58.140):
In Reply to: Looking for info on a farmall H sickle bar mower. posted by Chad Penny on October 07, 2002 at 05:24:24:
Over the years there were a half dozen or so different mowers used on Farmall H. Most of them however had a cross bar that matched the drawbar hole for hole. To hitch to them you just had to move swinging drawbar to extreem left, back up to mower, put two bolts through mower bar and drawbar, hook pto, if hydraulic lift couple that and you were away. All those mowers had rear caster wheels. Then there was the 16 for some reason, great mower, also great knuckle buster installing and removing Unless you have a cross bar that matches drawbar and caster wheel you most definately have a 16.
Post A Followup
: Re: Re: Looking for info on a farmall H sickle bar mower.
