Re: scottyNY help !
Posted by ScottyNY on October 09, 2002 at 05:58:56 from (128.59.123.240):
In Reply to: scottyNY help ! posted by jon mirgon on October 09, 2002 at 05:32:17:
Jon, there are two bearings on that shaft. At the tranny end, it seats in the bearing retainer cage, which is secured with three bolts and shims underneath. The outer end has a bearing held on with an odd shaped ring. I'd make sure the shims on the inner end are very clean (it doesn' take much dirt to change that clearance), and that the outer bearing is driven all the way onto the shaft and fully seated in the final drive housing. Also check to make sure that the brake drum isn't restricting the length of the shaft as it goes back to the tranny. I found one of my drums doing that. It's an old machine that had some play to begin with, so you won't get rid of all of it, but if you've got your bearings seated right and the shims under the bearing cage and the brake drum right. That's about all you can do on the outside. If the play poses a problem when underway, there may be (I'm not sure, my books aren't here) some shimming you can do on the differential gears. Hope this helps
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
