Re: FARMALL A Hour meter
Posted by brianh on October 09, 2002 at 06:02:55 from (216.153.236.122):
In Reply to: FARMALL A Hour meter posted by Chris on October 08, 2002 at 06:09:28:
Another easy way is to just connect it to the armature terminal on the generator. When the engine runs and drives the generator, it makes voltage and the hour meter runs. (Courtesy Bob M)
Post A Followup
: Re: Re: FARMALL A Hour meter
