Re: Re: Farmall H Carburator
Posted by jal-SD on October 09, 2002 at 08:48:30 from (64.68.166.199):
In Reply to: Re: Farmall H Carburator posted by Don LC on October 09, 2002 at 04:44:25:
Your dealer should have the carb gasket as a separate item. Bought one for my '44 H just a couple of weeks ago from my dealer. If I remember right, they are the same for both types of carbs. Also get the gasket that goes between the carb & intake-when these leak, they can cause the problems you describe. They are available separately, too. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Re: Farmall H Carburator
