Posted by Janicholson on March 28, 2009 at 06:49:30 from (66.173.50.8):
In Reply to: M starter questions posted by Rich in WI on March 27, 2009 at 21:27:57:
If it needs the soldering (make sure it is broken before fixing) Then do it, or have it done. Replacing the starter drive with a clutch style drive gear will make a dramatic difference. The reason it might have "failed" each time might have been the drive jamming in the ring gear. Each time you took it out it unjammed and then worked for a while (or not) and jammed again. If the ring gear teeth are toast, and all smashed over on the leading edge, dressing them with a file might help. There will be primary spots where the engine usually stops, so turning the engine will show them in the starter opening. If the teeth on the ring gear have less than 1/2 of the material left, the new drive might not make it better, but it is worth the try. To replace the ring gear requires splitting the tractor in two at the clutch. Best of luck, JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
