Re: Neutral safety switch on IH-574
Posted by Al on October 10, 2002 at 13:16:24 from (64.4.101.140):
In Reply to: Neutral safety switch on IH-574 posted by Brad Rackers on October 10, 2002 at 11:47:37:
The switch is wired in between the starter solenoid S terminal and the S terminal on the key switch. The switch is located on a bracket under the left side of the dash near the clutch pedal pivot When you press down on the clutch pedal the pedal pivot pushes in the plunger on the safety switch. The switch is a small round switch with 2 terminals on the back and a plunger on the front and mounted throught a hole in the bracket held in place by a ring nut.
Hope this helps.
Post A Followup
: Re: Re: Neutral safety switch on IH-574
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
