Re: Brake Adjustment - IH 444
Posted by Al on October 10, 2002 at 13:29:40 from (64.4.101.140):
In Reply to: Brake Adjustment - IH 444 posted by Allen R on October 10, 2002 at 09:38:28:
You adjust by turning the nut on the rod going to the brake from the foot pedal. The way I adjust mine is jack up rear wheels and adjust until just drags and let off until no drag. adjust until both pedals have the same braking applied height. If they are frozen you will need to disassamble and clean. The expander balls are probally rusted and the wear plates are the same. Clean them up and coat with a good rust preventative such as anti seize where the balls roll and the plates pivot not on the brake surfaces. Do not paint. I did this on mine about 5 years ago and have not had any more problems.
Post A Followup
: Re: Re: Brake Adjustment - IH 444
