Re: H-powered wood splitter?
Posted by JIM on October 10, 2002 at 19:36:48 from (67.250.198.62):
In Reply to: H-powered wood splitter? posted by Al Reisman on October 10, 2002 at 18:23:11:
I use my H. It is set up with a pressure hose out the normal elbow from the side of the tractor belly pump and a return to the bottom of the belly pump. I use hytran and no auxillary tank. It seems to work fine.
Post A Followup
: Re: Re: H-powered wood splitter?
