Re: H-powered wood splitter?
Posted by gene b on October 11, 2002 at 02:17:07 from (63.15.137.98):
In Reply to: H-powered wood splitter? posted by Al Reisman on October 10, 2002 at 18:23:11:
the size of the cycl is THE BIG thing as it is area of the piston x pressure=force also the bigger the piston the slower it will cycle but that is no big deal. but the bigger the more force as your pump should have around 1000lbs you will also have to have a two-way control in the hy to make it two way as the original valve is just single pressure and the load would retract the cycl.
Post A Followup
: Re: Re: H-powered wood splitter?
