Re: Old Raceway M Update-UH BERMUDA KEN!!!
Posted by Irv on October 11, 2002 at 19:06:20 from (152.163.189.203):
In Reply to: Old Raceway M Update-UH BERMUDA KEN!!! posted by The Red on October 11, 2002 at 14:15:23:
Red, When I put the new bearings in my H, I just about froze - The crank would not turn over at all. I did not even have the bearings up to torque - I was really puzzeled. I finally found out that I had a little sliver of metal under the #3 M/B. That was enpugh to tighten everything up. Cleaned everything up and it worked great. Good luck Irv
Post A Followup
: Re: Re: Old Raceway M Update-UH BERMUDA KEN!!!
