Re: HAIR LINE CRACK IN PUMPKIN .
Posted by Steven@nd on October 11, 2002 at 20:12:06 from (12.23.184.22):
In Reply to: HAIR LINE CRACK IN PUMPKIN . posted by Geoffrey on October 11, 2002 at 19:44:54:
If it isn't of structural necessity (meaning it isn't going to crack anymore when you hit a bump or pull something) I would grind it out a little bit and use your favorite epoxy (ie JB Weld) on it.
If it is something that could crack more, I would V it out and use a nickel rod and weld it. OR take it to a welding shop that can weld cast.
Another good piece of advice, if it is cracked into the plug threads, screw a piece of pipe into the hole before welding and put a cap on it, use the pipe to drain so you don't have to disturb the crack again.
Steven
Post A Followup
: Re: Re: HAIR LINE CRACK IN PUMPKIN .
