Re: 1944 M
Posted by Farmer Bob on October 12, 2002 at 23:45:02 from (66.152.73.65):
In Reply to: 1944 M posted by Brad Kimball on October 12, 2002 at 22:29:12:
Brad, If there is a control arm coming out of the right side of the torque tube underneath the belt pulley drive, and one elbow on the right and two on the left side of that tube, you more than likely have the liftall. There is an inspection plate on the bottom of the tractor that you can remove and look up in there for a large round shaft connecting the transmission and the liftall pump. Sometimes that shaft is removed if they didn't want to use the lift-all.
FB
Post A Followup
: Re: Re: 1944 M
