Re: Re: Re: BN rear axle disassembly
Posted by Red Dave on October 13, 2002 at 14:59:42 from (67.242.31.54):
In Reply to: Re: Re: BN rear axle disassembly posted by Jeff on October 13, 2002 at 14:07:46:
1. You must remove the final drive from the differential shaft housing to access the brakes on the right side. You remove the differential shaft housing from the differential to access the left side brakes.
2. The differential shaft slides right out of the differential, it is a splined shaft. The drums are on with a key, you may need to press or pull them off the shaft, depending on the amount of rust.
3.The brake band is an external contracting band, it fits on the outside of the drum.
If you need more info, you can e-mail me and I will try to copy the parts diagram for you.
Post A Followup
: Re: Re: Re: Re: BN rear axle disassembly
