Re: Re: Re: farmall 460 rear axles
Posted by Hugh MacKay on October 13, 2002 at 21:17:39 from (209.226.106.169):
In Reply to: Re: Re: farmall 460 rear axles posted by Salvage Man on October 13, 2002 at 20:24:57:
So what you are saying is the 2-3/4 axle for 460 was a special part and not a 560 axle. At the inner bearing and bull gears it was same size as 460 original axle. Just want to get this one straight. I am still bruised from last time.
The interesting part of all of this is the first time I ever saw a 460 new at dealers, I said it was a dud. For very little more money you could have a 560, same dimensions and wheel base as 460.
I saw the same when buying new 1066. 966 was $1,200. less and 766 was $2,000 less. 1466 was less than $1,000, more than 1066. The only item that stopped me on 1466 is dealer said no 540 take off. It was by far the cheapest hp. I have since seen dual take off on 1466.
Post A Followup
: Re: Re: Re: Re: farmall 460 rear axles
