Re: Oil Bath Air Filter
Posted by Michael soldan on October 14, 2002 at 09:59:21 from (216.46.130.16):
In Reply to: Oil Bath Air Filter posted by Dave IL on October 14, 2002 at 09:46:58:
Dave, I have two 1944 H's and I use the same weight motor oil in the oil bath as is in the crankcase. I could only imagine the engine sucking oil from the oil bath if it was totally overfilled other wise, I am sceptical that it could happen. I am interested in your comment about the tune up. If the carb is not set correctly or your engine valve timing is off you could get smoking and wettness on the plugs. I would suggest a compression test to answer your concerns. If you don't have a compression tester you can borrow or rent one and it doesn't take long to check. If your cylinders are all within 10 lbs of each other and they are between 90 and 120 your smoking is not likely related to ring, sleeve, piston but carb, timing etc. I have one H that is 85lbs across the board and it really doesn't smoke much once it is warmed up. If it has been idling and you open it up it gives oil smoke for a moment , then clears up. I suspect the "tune up" as you indicated. Good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
