Re: 966 PTO
Posted by AceS on October 16, 2002 at 04:51:54 from (67.0.26.59):
In Reply to: 966 PTO posted by Redneck in TN. on October 15, 2002 at 22:20:16:
You could be low on oil but most likly the sucksion tub seal is bad or the tub is loose that feeds the PTO punp you could take off the Third link plate just above the PTO and check to see if is loose if seal is bad when you go down hill and the seal is uncovered it will not get enough oil.
Post A Followup
: Re: Re: 966 PTO
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
