Clockwise on the dist (Looking from back to front of tractor). The Wiring is found below. I will ad that a automotive style fuse link is a great idea installed where the wire to the amp meter attaches to the starter switch. this fuse looks like a piece of colored wire, and is rated like a fuse in amps. It should be rated at 10% over the alternator max output. Wire it in but leave the colored wire exposed. Use mechanical connectors to attach each end to the switch post, and the wire to the amp gauge. Use shrink tubing to prevent corrosion on the connections. A fuse link prevents wiring fires from grounded connections and saves letting the smoke out of the entire tractor. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
