Re: 806 transmission dipstick ?
Posted by KX on October 17, 2002 at 06:58:16 from (66.129.8.2):
In Reply to: 806 transmission dipstick ? posted by TL on October 16, 2002 at 14:09:02:
Both my 806 have chewed on the hytran stick. One is almost eaten through. I now bend them slightly and make sure they lean slightly toward the outboard side of the transmission casting. As for getting yours out, I don't know. I would TRY the telescoping magnet and if no luck try fishing it out with a wire. Hopefully and most probably, this has fallen and is flat on the bottom of the trans casting. If it gets in the gears...could be bad. Good luck.
Post A Followup
: Re: Re: 806 transmission dipstick ?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
