Re: Re: Re: Hydraulic Pressure
Posted by Scott Swanson on October 17, 2002 at 10:27:10 from (209.180.31.9):
In Reply to: Re: Re: Hydraulic Pressure posted by Layle Willis on October 17, 2002 at 10:17:17:
I think you should be able to lift 500 to 600 pounds. If your pump is an improved one, you should be able to lift more like 800 pounds. Be aware that the loader will work only if the clutch is not pressed in. The belly pump runs off of the counter shaft in the tranny. It is not Live.
There is a way to make it double or triple acting but I am unsure of the procedure. It needs extra spools to do that.
If you only use the belly pump and its related controls, it will only be a lifting bucket. Weight will have to bring it down. You will need a trip loader.
I am sure more people will sign on and help you out. My knowledge is limited as well. I am in the same boat as you.
Post A Followup
: Re: Re: Re: Re: Hydraulic Pressure
