Re: Re: Re: Hydraulic Pressure
Posted by Roger on October 18, 2002 at 02:48:05 from (57.72.140.2):
In Reply to: Re: Re: Hydraulic Pressure posted by Layle Willis on October 17, 2002 at 10:17:17:
Scott, I have an early Super H and with a old Model 31 International loader. I use the belly pump hydraulics and it has been able to lift anything I ever wanted to lift. I have loaded the bucket heaping full of wet/compacted manure and it will lift it (hard to steer with that much weight). I have the back side of the cylinders piped to a tee in the oil fill pipe on the belly pump, that way if there is any leaks from the cylinders it goes back into the belly pump resoirvor.
Are you sure you have a Super H. I didn't know any Super H's came with a magneto. Roger
Post A Followup
: Re: Re: Re: Re: Hydraulic Pressure
