Re: M starter questions
Posted by sflem849 on March 28, 2009 at 07:11:00 from (66.254.196.101):
In Reply to: M starter questions posted by Rich in WI on March 27, 2009 at 21:27:57:
I second the 5th gear trick. Most M's will require this about one every 100 times they are started. Every tractor I have driven seems to do this from time to time.
If it is worn ring gear teeth you can take a flat screwdriver and turn the ring gear to a good spot so the starter will engage. Don't forget, it is even trickier than splitting the tractor to get at it. IIRC you have to put the gear in a fancy oven to expand it and then place it on the flywheel.
