Re: Re: Re: A swap from a IH H to a J.D. A or G ?????
Posted by Doug in OR on October 19, 2002 at 17:49:47 from (12.225.51.197):
In Reply to: Re: Re: A swap from a IH H to a J.D. A or G ????? posted by carl on October 19, 2002 at 17:17:28:
A TA will put your tractor in a non-original class. Not a good idea unless you want to spend big $$$. Rather than going that route, get one that comes with a TA. Remember, a TA will add weight... lots of weight. Are you killing the motor in first gear? My M always spins out. It does pull farther, much farther, when I let the tire pressure way down. Don't be afraid to go down to 4 or 5 psi. It scares me when I look at the tires while pulling, but it just keeps on chugging.
Post A Followup
: Re: Re: Re: Re: A swap from a IH H to a J.D. A or G ?????
