Re: A swap from a IH H to a J.D. A or G ?????
Posted by Red Ryder on October 19, 2002 at 18:12:43 from (204.119.225.102):
In Reply to: A swap from a IH H to a J.D. A or G ????? posted by carl on October 19, 2002 at 14:20:08:
there are a lot of things you can do to increase the horsepower on your H,you can bore and stroke it, put on lp head,do manifold work,rebuild the carb.,adjust the timing.You can make your H outpull an JD A and some Gs it depends on your rules and how much work you want to do. 60 to 70hp. is possible from a H. To get low speed gears you will have to get used ones. With big power you don"t need any different gears.
Post A Followup
: Re: Re: A swap from a IH H to a J.D. A or G ?????
