Farmall Tractors Discussion Board
Re: Bevel bolts for mounting implements on A
Posted by John C. on August 24, 1999 at 08:20:12 from (12.13.248.14):
In Reply to: Bevel bolts for mounting implements on A posted by Marvin on August 24, 1999 at 08:01:31:
I think that the implement mounting bolts are the same as the wheel lug bolts. Take one of your wheel hub lug bolts off and check to see if it threads into the implement mounting hole. If it doesn't, determine the nominal diameter and threads-per-inch and ask for wheel mounting lug bolts at the auto parts store. The hex head on the wheel lug bolt will probably be a size smaller than the regular implement mounting bolt head, but I think the two bolts have the same amount of contact area in the tapered section of the head. Hope this helps.
Post a Followup
: Re: Re: Bevel bolts for mounting implements on A
