Re: 154 Low Boy
Posted by John M on March 28, 2009 at 07:34:05 from (209.213.22.170):
In Reply to: 154 Low Boy posted by BlakeinTN on March 27, 2009 at 19:23:00:
Mine comes off of the pto pulley, down to the two lower pulleys, then onto the main pulley. The "twist" is from the pto pulley to the two lower ones.(More like a half twist on each side) You use the two pulleys to tighten the belt. Sounds like its loose or the belt is worn out, or you have too long of a main belt.BTW, mine is the IH Danco mower, not a Woods.
