Super C air in hydraulics
Posted by MelL on October 21, 2002 at 15:34:24 from (64.68.247.84):
I've posted this before and got good suggestions but still not working out. I have a Freeman loader on my C with about a two quart reservoir mounted above the standard reservoir/hydraulic unit. As soon as I start the tractor I get air coming back up that connecting hose. Have replaced O-rings between hydro manifold and touch control pump and the gasket between manifold and hydraulic unit. See no leaks hear no leaks. Anyone want to make a suggestion what to check/replace next. How about the temperature sending unit If the cable is broken could the solder joint at the cover plate be drawing air? Cylinder head gasket?
Post A Followup
: Re: Super C air in hydraulics
