Re: need help with engine problme
Posted by carl on October 21, 2002 at 16:06:09 from (208.40.155.79):
In Reply to: need help with engine problme posted by STEVEN HESSELGRAVE on October 21, 2002 at 10:45:41:
well an H usally doesnt have a dipstick. MOST H's have what looks a little like drain pepcocks for rads that are mounted on the side of the oil pan. The top one is full and the lower one is low. The knock your hearing if your 100% sure its not a rod or a crank bearing very well could be either piston slap or a wrist pin. Does the knock go away under a load or when you throttle it?
Post A Followup
: Re: Re: need help with engine problme
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
