Re: Engine kit from NAPA
Posted by Boochie on October 21, 2002 at 19:11:29 from (216.10.181.114):
In Reply to: Engine kit from NAPA posted by I RIGHT I on October 21, 2002 at 15:50:41:
My father and I overhauled his Super "C" 15 yrs ago with a overhaul kit from NAPA. For 8 yrs he used the tractor 4x a week to pull a old hammer mill (which you know is hard to pull) to grind feed which took about 1 to 2 hrs with the trottle on wide open. The pipe is white on the tractor and cranks right up with either the starter or one half turn of the "old hand crank". She runs good and uses no oil nor does the tractor knock. I can say the overhaul job that he did using the NAPA kit was a success. Good Luck with your tractor, to me the old ones are the best.
Post A Followup
: Re: Re: Engine kit from NAPA
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
