B414 hydraulic lift problem
Posted by Dale O on October 21, 2002 at 21:54:54 from (152.163.189.203):
I found that someone had the same problem I am facing. Unfortunatly there was no follow up to tell if the problem was solved and if so how.
Once I find the cure I will be sure to post it for those who follow.
Dale
In Reply to: Need help with IH B414 hyd sys posted by Bill pack on August 22, 2002 at 14:47:01:
I don't have the answer for you, just the same problem and wondered if you had yours cured yet and how. My problem is the draw bar will just barely lift with no load, will not lift when standing on it. (Tractor does not have power steering or loader.) Crack line at hydrualic pump and get a trickle but no pressure, but it is not a pump problem as this pump was put onto another tractor and has great pressure
Post A Followup
: Re: B414 hydraulic lift problem
