Re: Super A Carburator help
Posted by Allen R on October 22, 2002 at 04:46:50 from (168.9.128.4):
In Reply to: Super A Carburator help posted by Reddog on October 21, 2002 at 16:57:05:
I have always cranked the tractor rev up to high
speed move the mixture screw in to rough then back
out to engine is rough again then back in to I
think sound is correct - move throttle to low
speed then if carb is correct you should be able
to move back to high speed with throttle with
little or no hesitation from the carb. I agree
with prior posts that engine will not get down
to low rpm idle is somewhere between your throttle
and carb...Always be careful - neutral gear - etc
when working off that tractor and engine running..
Post A Followup
: Re: Re: Super A Carburator help
