Re: 966 Steering Cyl.
Posted by cbont on October 23, 2002 at 11:21:34 from (207.54.105.157):
In Reply to: 966 Steering Cyl. posted by Redneck in TN. on October 23, 2002 at 06:33:20:
The piston on this cylinder if its the same as on our 1066 is only pressed onto the rod. Ours was knocked off center one time 15/16 yrs ago making it steer to far one way and not far enought the other. All I did was press the piston back to its proper position on the rod and we put a new seal kit in it when I had it apart. Its a very tite press fit.
Good Luck
Post A Followup
: Re: Re: 966 Steering Cyl.
