Re: f12 wide front
Posted by ET on October 23, 2002 at 11:28:50 from (134.179.136.130):
In Reply to: f12 wide front posted by luke on October 23, 2002 at 03:08:03:
Wide fronts for F12's are few and far between. The last price I heard was $1800 for a rebuildable axel. The bearings are no problem if you get the correct 16" front wheels for the axel. The inner bearing has a smaller inside diamater than the ones used on a narrow front. I made a sleeve to go on my axel so I could use the same bearings but I have heard there is a bearing available that will work without the sleeve and it is probably pricey.
My next Farmall is a F20N with a wide front to go along with the F12 wide front.
Post A Followup
: Re: Re: f12 wide front
