Re: The Weakest Link...Is This Supposed To Happen?
Posted by Terry Johnson on October 23, 2002 at 18:39:24 from (216.51.195.31):
In Reply to: The Weakest Link...Is This Supposed To Happen? posted by Salmoneye on October 20, 2002 at 04:28:21:
I am in agreement with the gentleman to cut up your loader frame! I would block up each half of the tractor, remove the loader and use the loader frame rails on either side of the tractor, like a splint on a broken leg. Bolt the end of the loader frame rail to the front end with the other end over the rear axle housing. Using chain and load binders under the break, fasten to both loader frame rails to act as a sling to carry the weight of both halves. This should get you back to your shed, if you stay under 5 mph.
Post A Followup
: Re: Re: The Weakest Link...Is This Supposed To Happen?
