Re: International A414 High clearance
Posted by Hugh MacKay on October 24, 2002 at 19:52:51 from (64.228.13.171):
In Reply to: International A414 High clearance posted by Damon on October 24, 2002 at 16:44:32:
This is the tractor we know in North America and indeed in Euorpe as the B414 or British built tractor. Am I correct on that, same tractor just used A for built in Austrailia. Most of them were sold with 12x 28 tires, and the hi-clearence had 12x38 with longer spindles on front. I don't know if they changed rear end ratio to compensate for larger tires on drives. If all of this is as I am assuming, should be a great tractor for what you want to use it for.
Post A Followup
: Re: Re: International A414 High clearance
