Re: 606 runing problem
Posted by Stan on October 25, 2002 at 10:35:08 from (207.5.186.62):
In Reply to: 606 runing problem posted by Ron on October 24, 2002 at 16:35:47:
Another likely culprit is ignition. I know you have spark when you first start it but sometimes they develop what we call a "heat related intermittent". That is why if you leave it for a while it will start and run ok for a little while, after they cool down, and then stop again when a component gets to a certain temperature. I would check for spark when it acts up. Possible components to check are coil and condenser. These are both known to develop heat intermittent problems. Just my 2 cents worth. Good luck
Stan
Post A Followup
: Re: Re: 606 runing problem
