ta and hyd problem
Posted by walter frazier on October 26, 2002 at 20:39:05 from (24.229.176.103):
I have a 340 IH farmall tractor I've installed a loader on tractor when I'm pushing into a pile with loader I can't back up tractor won't come out of 1 st gear to shift to reverse unless I lift bucket up to take load off then it will shift rigth in.Tractor shifts and runs fine with no load but seems to be in low range.Will this tractor run a loader with its hdy gear pump?loader seems to run slow,the loader came off a 800 ford.Can I mount a bigger pump?I would like to keep tractor but if I can't fix loader problem I will get rid of tractor.Thanks for any help
Post A Followup
: Re: ta and hyd problem
