Re: needing help diagnosing a M fuel problem.
Posted by John (SC) on October 27, 2002 at 05:31:43 from (206.74.216.43):
In Reply to: needing help diagnosing a M fuel problem. posted by Dan on October 26, 2002 at 21:46:35:
Next time it does it,open the drain on the carb and see if gas flows out good.If so then you have a ignition problem.If the gas doesnt flow then you have a fuel problem,could be a problem in your sediment bowl.You didnt mention that.
Post A Followup
: Re: Re: needing help diagnosing a M fuel problem.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
